Peter Johnson
- Nov 12, 2000
If I build my sub with a set of those dual binding posts, with the metal bar connecting the two sets, is it possible to wire each VC to 1 of the sets of posts?
So with the bar in place, it is a normal 4 ohm load, as the VC's are in parallel, but if I remove the bars, driving as an 8 ohm load and a single VC, then I can simply attach a potentiometer to the other set of posts, and alter the Q of the system?
Seems very flexible to me, but is this correct?
