Josh Z
- Oct 3, 2001
“Strange things are afoot at the Circle-K.”
Okay, I need some input. I just bought a Samsung HCL4715W Hi Def widescreen RPTV, and it is an incredible set, but something weird is happening with the 1080i input. Either that or I’m a complete tool and I’m missing something. I’m willing to accept either scenario is a possibility
This is gonna get involved, so hang in there:
On my HDTV there are 2 component inputs: 1 marked for 480p and 1 for 10801. I currently use 1 for my Progressive Scan DVD player, and the other for my XBOX. When I use the 1080i input for the DVD player it looks outstanding when it is in Progressive Scan Mode. When I switch the DVD player to interlaced mode, the picture became completely scrambled, transparent and seemingly split down the middle and pushed to the sides of the screen (I know that doesn't make a lot of sense, but I don't know how else to explain it!).
Next, when I have the XBOX on the same input (1080i) the initial XBOX console menu is scrambled the same way, so that it's impossible to make out what is on the user menu on the screen. But, when in actual game mode the PQ is, again, spectacular. The XBOX is set up correctly for 16x9 1080i output.
Now on the other input (480p), both machines look great in all modes.
What the?!?!?
I do not yet have an HD STB, so I have been unable to test either input with a 720p or 1080i signal.
This is a problem because I would like to keep the XBOX on the 1080i input, because it is capable of 1080i output (though, no current games take advantage of this just yet). Also I am very concerned that there is a problem with the 1080i input that will affect when I do get a HD set top box down the road, causing similar problems with HD/SD signals. Yikes!
So to make a long story short (Too late for that):
Component Input 1 (1080i): 480p DVD good. 480i DVD messed up. XBOX (480p) in-game good. XBOX menu screen messed up.
Component Input 2 (480p): All Xbox and all DVD modes good.
So what is the problem? Can it be fixed? Do I need to have a Replacement delivered before the first 30 days is up?
So,There you are. Are you sorry you asked?
Sorry about this voluminous tome. Thanks for your time, opinions and advice!
Cheers,
Josh
What the?!?!?
Cheers,
Josh
