Can anyone tell me if there is one s video cable better than another and how much of a difference do you really see between the different companys thanks for any advice.
Check out the "QuadCat" S video cable at Link Removed Hand made, excellent quality cable. Doug will take care of you, thats for sure. Good luck!
- Chip
Mike when I switched over from a decent but cheap RCA branded s-video cable to my current thick AR cable there was enough of a difference that I had to recalibrate my TV with Avia. Although there's often heated debates in differences in audio cables most people seem to agree that there are quite visable differences b.t low end video cables and better quality ones.
http://www.attcanada.ca/~itisi
