RS 15-2104 Remote Control (1 Viewer)
Patrick Larkin
Hi --
does anyone have the new version of the much beloved 15-1994?
I bought one and am having difficulty programming macros into the 4 SMART keys (1s -4s).
I can program Macros no problem into the Movies, Sports, etc buttons.
Thanks.
Wes
Utah USA
Wes Peterson
I also have'nt been able to do it either, but I have not looked at great detail on if it is possible. Try posting this question at www.remotecentral.com perhaps someone there has found a way. I have noticed that if you screw a macro up while putting it in to the new keys you have to delete it before you can write over it. The 1994 I believe you could just write over the messed up one.
Wes
JoeyT66
