Alan Howard
Grip
- Aug 15, 2003
Hi all,
I now have my new AVM-20 tweaked and sounding really good. Finally, 5.1 at last. I'm using an all Mirage setup: OM-7 fronts, OM-C3 Center, & OM-R2 surrounds. Also a Mirage BPS-150 sub. ANthem MCA-5 amp by the way.
Now, when it was just a 2-channel and sub system with an Adcom 2 ch preamp, it sounded good. Now it's very bright in the 2K to 8K range. I have hardwood floors and thin curtains. So where should I start?
A rug covering the floor between sofa and Fronts?
Wall treatments?
Or Heavier window treatments?
I'm also only using the RCA inputs/outputs on the preamp-amp connections. Should I move to Balanced IC's first or last?
Any help you guys could provide is greatly appreciated...
Alan
Wall treatments?
Alan
