I just purchased a home that came wired for sound and they also left behind a set of Bose surround sound speakers and a couple amps. However, there is no receiver to control the set up. Here is what I have:
Ceiling-mounted Bose cube speakers
Bose Built-INvisible Acoustimass Module II
Bose BUILT-INvisible TA-2 Theater Amplifier (in basement)
There are also two separate Bose Llifestyle SA-2 Amplifiers (in basement), which, as best I can tell, go to: 1) a set of outdoor speakers on the patio (which are still there); and 2) a set of speaker wires coming out of the floor in a formal living room (no speakers).
It appears that whatever controller they had previously, they connected it via BoseLink A cables.
Given some of the comments I have seen elsewhere on this forum about the quality of Bose speakers, I can guess why these were left behind.
Does anyone have any suggestions as to a receiver that would work with this set up? I am expecting that, at a minimum, I will have to get rid of the BoseLink connections and pare it back to individual speaker wires.
While all suggestions are appreciated, I do not have the budget to completely replace the entire system, including all speakers. If that is the only viable option, I will simply be going without for a few years at least. However, if the reality is that it would be better to wait and start from scratch as opposed to spending a smaller amount of money on the current system, I would appreciate that viewpoint as well.
Thanks in advance for your input.
