- Feb 3, 2004
- Sam Favate
Thinking of finally getting a DVD recorder (separate from the one in my computer) and I have a few questions:
- Will the DVD recorder function like a VCR? Can I set it to tape shows when I am not home/asleep/etc. (I do not have a DVR or Tivo).)
- If you record several shows through a DVD recorder, can you access them independently? Or do you have to "fast forward" through the first one to get to the second and so on? Is there a menu that indicates "program 1," "program 2," etc.?
- Is the DVD recorder technology outdated? I recall reading (I believe it was in the The Digital Bits book) that DVD recorders weren't ready for mass use because they were using old standards in terms of compression. But if I just want it to function like a VCR, will it do the trick?
- I also want it to copy old home movies on VHS and VHS8mm. Can it copy these and allow me to make menus, chapter breaks, etc.? Or am I better off using the computer for that? (The problem with the computer for me is two-fold -- 1) I have to move the VCR into the computer room and hook it up, which is a pain, and 2) it takes a monumentally long time.)
I really appreciate any advice you can offer. Thanks in advance.
