ThomasL
- Mar 13, 2001
Ok, according to Toshiba the new 32HFX71 will do compression for 480p/480i sources through the component inputs. In the manual, they list 3 different modes: normal, letterbox, and compression. When using compression mode, they say that there is a greater chance of engraining stationary images on the picture tube since there is no raster in the black bars on the top and bottom. I don't quite see how that increases the chances of burn in on the part of the screen that actually is part of the raster. I can see how over time, you'll get an uneven phopshor use with the 16x9 area being worn more than the top and bottom, but I don't see how this will lead to a better chance of burn in of a stationary image anymore than just a regular stationary object on a 4x3 screen (normal picture mode). Can anyone clue me in?
btw, there doesn't seem to be any mention of an automatic compression being done.
thanks,
--tom
thanks,
--tom
