MarcoBiscotti
- Sep 2, 2003
This machine is giving me so many problems I just don't know what to do!!!
First, I'll start by giving a breakdown of my setup...
The Pioneer is connected via component cable to an HD Leeza scaler and output to my DLP front projector at a native 1280x720 res (60Hz).
The image I am getting from the Pionner is plain UGLY!
Loads of digital noise and artifacts, and it does NOT handle motion sequences well at all!
I have the Pure Cinema mode turned OFF, and the progressive scan is set to 'Auto 1' which is supposed to be the best de-interlacing function.
Let me explain what I am seeing...
First of all, the image appears extremely soft and in detailed shots (such as a forest of trees or a close-up of a brick wall) the ammount of digital noise disturbance and scattered pixels is terrible and very distracting!
Another major issue I have is with compression artifacts, especially noticeable in motion sequences!
Often, the result of such appears in the form of an interlacing error where a flicker is seen in solid lines and any hard straight edges of the image experience a slight jitter which is very quick and subtle but still quite apparent if one were to watch with a discerning eye.
It's very distracting and downright ugly!
It also happens to be most apparent in animated titles for some reason. I have some R2 PAL DVD's of The Charlie Brown & Snoopy Show and the effect renders them almost unwatchable!
I've tried nearly every progressive mode too..
For example, when Charlie Brown turns his head to speak to Schroeder, the solid lines around his mouth flicker and break up. Of course this all happens within a matter of single seconds, but it is consistent when watching DVD's.
I've never noticed it to be as bad as these R2 German sets which I have, and I am certain that it cannot be an issue with the DVD's themselves as they have received all around rave reviews on Amazon.de and elsewhere that I have checked with excellent feedback in regards to the image quality. The restoration done to the video transfers are far superior to the Charlie Brown DVD's I've previously owned from Paramount in R1. So I can only guess that my setup is to blame!
I'm just really unhappy overall with the performance of my Pioneer, and for the price I paid for it, I really would have expected better quality!
I cannot believe that what I am seeing howver, is an accepted standard amongst these players. In fact, it's impossible!
The 59-AVi is supposed to be a top-of-the line contender, voted "Player Of The Year" by Home Theater Secrets last Fall and has been fishing the highest reviews accross the board. For the $1,000 + price tag I paid for this unit, I am certainly NOT seeing equal quality!!
Can anyone please help me out and offer feedback as to what the issues might be?
MAJOR UPDATE:
I now have an even bigger problem!!!
I just went to turn on the Pioneer to see what I could do with the remote functions, perhaps to test out the "fast-slow" function of the progressive option in the top menu.
As I fired up the DLP and switched the Arcam amp to the appropriate channel - when the Pioneer screen came into view, the entire image was distorted and appeared in split screen with the borders of the menu image being cut off at either end by the split sides of the screen frame!
It almost appears as if someone placed a mirror down the center of my screen causing the image to double, and than lowered the brightness and contrast levels making it very difficult to see altogether!
How on earth did this happen and what the hell do I do about this now?!
PLEASE HELP ME OUT!!!
MAJOR UPDATE:
