Darren Pillans
- Feb 25, 2000
Hi all,
As I live in Australia, I don't have the advantage to audition U.S. models "in the flesh", so I'd greatly appreciate your help.
Fistly, can the Pioneer DV-440 and DV-343 play the PAL color format?
Can they be modified to play multi region discs without the use of a screw driver?
I've looked at the Pioneer website and the only difference I can see between the models is the 353 can't "frame by frame" in forward and reverse. I assume the 440 can.
Surprisingly, not many low end players can do this. It's great for analysing special effects shots and editing technique. The 440 also appears to have better build quality.
Secondly, are there any other differences between the two models?
Lastly, can someone recommend the best site to get these players?
Many thanks in advance.
DARREN
DARREN
