kathy_parsons
- Apr 26, 2004
hi,
ive just got the above recorder, as it states it can record NTSC signals as well as PAL.
I have some NTSC vhs tapes i want to put onto dvd, they play fine through my video recorder and display fine on my tv (which is multistandard).
but when i tried to record them using the NTSC setting on the recorder, it only records in black and white. when i tried in in PAL just to see what would happen, i got the colour but the picture is shifted up.
i dont understand why its not working, when the recorder is switched off and the NTSC signal loops through from the video straight to the tv there is no problem.
i tested the file i recorded with the player set to NTSC by looking at the info on the pc, and it does show as an NTSC file, with the framerate etc all correct - so why no colour!!!!!!
annoying.
kath
annoying.
kath
