MarcoLanz
- Mar 15, 2006
Hello,
I have a region free Denon 2910 DVD player with
an in-built 16 MB PAL-NTSC converter connected via HDMI to a Sony SXRD. The DVD player upconverts to either 720p or 1080i.
Well, NTSC DVDs look fantastic, almost HD quality, but when I watch PAL DVDs and there are diagonal lines in the image(like a rope, a rifle, or the edge of a door), these lines look jagged: they do not look like straight lines, but more like a staircase. I believe the correct term for this artifact would be aliasing.
I have compared with the few DVDs where I also have the NTSC version, and the same scenes look fantastic in NTSC, without this artifact (They Live, Scanners, Prince of Darkness, Zulu...).
So, this seems to be a problem with the player/TV/setup and not with the individual DVDs, and with the SXRD's big screen, these problems are now more visible than before. As I am using the HDMI connection and upconversion to a HD format, I would guess that the Pal-NTSC converter is not even involved in this problem.
Do you know what may be the problem, and how to fix it? Any ideas will be appreciated.
Marco
Marco
