Camp
- Dec 3, 1999
I have some interface questios about the 950. I don't know if there is even enough information yet available to answer my questions.
Pardon me if these questions have been covered before...I'm just now learning about this pre/pro.
1. Is there an On Screen Display (OSD)?
2. Is set-up and other information available on the display too?
3. If there is an OSD can it display via the component output?
4. Can you assign custom names to the various inputs? -or are you stuck with "video 3"?
5. I assume you can assign a primary surround format to use with any input (as you can do this with most receivers). How accurate is this feature on the Outlaw? My current receiver gets confused quite often and defaults to stereo without warning.
6. Can you assign custom volume levels to the various inputs?
7. Are the remote codes discreet? -any word on Outlaw providing discreet codes for Pronto users? -or are the set-up menus simple enough to make discreet codes unnecessary?
8. How does the display look from your seating position? I know this is a stupid question but I've found the Denon displays far too small. I'm kind of partial to the Elite and Yamaha displays as they are large, crisp, and full of good info. Can you dim the display?
9. Can my wife use it?
Thanks in advance,
Thanks in advance,
