and i am using component video will it not work with this reciverHow you wire things up can have a dramatic difference on how simple the system is to use.
Ideally, all audio & video would flow through the receiver so selecting sources uses 1 remote/button push.
My advice to you would be to:
- Run component video straight to the TV from the DVD player
- Run SVideo from EVERY other component through the receiver, including the DVD player (Yes, both outputs should work at the same time)
- 1 SVideo cable from the receiver to the TV.
Normal Operation: TV is seeing the SVideo feed from the receiver. You want to pause the DVD to channel surf on some other device, grab the receiver remote and audio + video switches with 1 button press. The wife/girlfriend/kids can all quickly learn to use the system.
For your serious DVD watching, you take the extra step to grab the TV remote and switch to the direct/component inputs. But then you must also flip the TV input back to SVideo to enable you to see the other devices.
Hope this helps.
