Jeff D
- Apr 6, 1999
I've got a question for 898 owners regarding video input.
The component video switching looks great. There is a problem I have with the composite to svideo conversion. I can run svideo and coposite out from most of my video sources to different inputs on the 898. For example I can run the LD output to video 1 on svideo, and video 2 via composite. I can run compsite and svideo out to input 1 (svideo) and input 2 (coposite) on my tv.
If the LD source is svideo and the reciever is ouput either svideo or composite the picture looks great. If the LD source is composite and the output is coposite to the tv it also looks great. If the input is composite and svideo is used to the tv I have problems. There is a cross hatch pattern that is visible on the tv. Almost always and much worse on colors like red.
First does anyone else have a similar setup? (kinda redundant to have svideo and composite inputs and outputs to the reciever, but for LD testing it was the only way to go) If you do have a similar setup can you tell me if you notice the same problem? The source can be any composite source to the receiver, the output needs to svideo for the problem to show.
Thanks for any help!
