Gabriel_Lam
- Mar 7, 2002
It really depends on your budget and what you want to do with it. Whenever you buy a computer, those are the 2 main things you want to clearly define first:
1. Budget
2. What you'll be using it for
I'd recommend if you're buying a computer for your mother, that you buy from a known reputable vendor (Dell, Gateway, IBM, HP, Apple, etc). That way, YOU'RE not stuck doing free tech support for her for life. Same kind of thing if you're buying this computer for a friend or relative.
If she's just doing word processing and things, she doesn't need a budget more than $350-600 or so, depending on how fast of a computer she wants.
I personally like Dell because I think it's the best bang for the buck by a good margin. I've owned computers from Dell, Gateway, IBM, Compaq, HP, Apple, Sony, Toshiba, and a loads of 2nd and 3rd tier manufacturers. I've also built loads of computers from individual components, including peltier & watercooling overclocked rigs. At this time, there's no beating Dell for performance for your dollar at the $350-1000 or so range.
1. Budget
