DrSteve
- Aug 21, 2006
- Steve
I've had something strange happen with my 3 year old Marantz SR7200. The center chanel appears to be dead! Sometimes when I switch between surround modes I will get about 0.5s of sound in the center chanel and then nothing. Several months ago the center chanel sounded "staticy" but I put this down to the source.
The speaker and speaker wire are good - I connected those to another output and got sound with no problems
I checked the amp set up and the center chanel is there and listed as "large"
I called Marantz and they suggested trying another speaker on the center chanel. Seems pointless. They also suggested a full system reset and promised to call me back to tell me how to do that.
Any other thoughts? I suspect it is likely a problem internal to the amp. Could I put a multimeter across the center chanel outputs and see if there is any kind of signal?
Many thanks!
Many thanks!
