Dave Falasco
- Oct 2, 2000
J/K, Dean.
Hey, all. I noticed we have three or four different threads discussing aspects of NFL 2K3. Several of them have posts with tips and suggestions for becoming more successful at this (admittedly difficult) game. Since we have the HTFFL gearing up in a few months, I thought it would be useful, especially for new people like myself, to consolidate the hints and tricks to one thread. I have gone through all the 2K3 posts and pulled out every useful suggestion I could find. Please feel free to either ask for additional help or to continue to post strategies or plays that you think other people would benefit from.
Please note, I have given credit after each suggestion (or set of suggestions if more than one was given in a post). However, if anyone feels uncomfortable having their words re-posted in this thread, please feel free to notify me and I'll remove your tip. And now, without further ado...
You can complete a pass, you MUST read the coverage, use pump fakes, and use smart play calling. Don't always throw on 3rd down and 6. Don't always run on first down. Rick Gregorio
On passing you have to throw to where they are going to be, the best way to do this is to use maximum passing. If your reciever is running an out to the right of the field then press right as your throw it. You can't just let him finish his route then stand there and expect him to catch it without the defender picking up on it.
For ps2 owners(im not sure about the other systems menus) go to camera options and turn pass zoom on. This makes the camera zoom out so you can see all of your recievers. Definitely helps.
Don't forget about your tight end. He can catch passes to.
Be smart, if your receiver is being double covered don't throw it to him and expect it to be a completion.
On run plays you have to follow your blockers, mainly your full back. I usually start out slow in the back field and build up my turbo arrow(correct term?) and once I see the hole develop I use a turbo move of some kind through. Then just try and go from there. Brett Hancock
You really have to pick your spots and read defenses in this game. If I overload the right side with receivers and run a weak side sweep, I can tell by the defensive formation whether Henry will get positive yardage before the ball is even snapped. Usually to break the big run, you have to have the right defense lined up, but you also have to get proficient with the jukes and stiff arms. Usually you have to make that first linebacker miss to get into the secondary. From there, it's gravy. Evan S
Hitting TRIANGLE (PS2) ( my note, this would be “Y” on the Xbox) when the ball reaches you helps catching. Charge up your X button (“A” on Xbox) before laying on the hit. Again, in the manual. Doing so you will see far less broken tackles. Doug R
On defense its really quite easy to stop the run. Call a run defense play and then watch the tackles. If they are in a 2 point stance(hands on their knees) its most likely a pass, audible to pass coverage, if they are in a 3 point stance(one hand on the ground) they're probably running it. Play actions and other plays do fake this so be careful with it and don't over commit. Mike Pattee
I've learned I can get the most yards by running to the weak side on most plays, and up the gut in Quad formation. Timing is the key for juking and breaking tackles Mike__D
(Q: How do I avoid having my opponent see the plays I am calling?) A: What you do is go to the play you want, select it by pushing A(xbox) or X(ps2), hold down the button and keep looking through plays. You can even change formations and pages of plays. once you release the button it will select the play. Mike Pattee
