Gus Valladares
- Aug 10, 2002
Hi Everyone,
I'm new in the Home Theater world. I just bought a Panasonic SC-HT95
Home theater.
(http://www.crutchfield.com/cgi-bin/S...s=0&c=4&g=3770
0&I=133SCHT95&o=p&a=0 )
I had a limited budget (no more than $500) for a
complete system. I thought this was ok.
One very important feature, for me was the ability to play MP3s.
BUT, I got a problem with different volumes and the bit rate. With certain
songs, the sound "jumps" Is
that normal?
My questions are:
1- What do you think about the Panasonic? Is that a good HT? (I can change
it!)
2- Is normal for the HT to jump songs written with a higher bit rate?
3- Any tip or suggestion, recommended links about Home theater are welcome.
Thank you very much!
Gustavo
Home theater.
that normal?
My questions are:
it!)
Gustavo
