Chris Shelly
- Dec 16, 2001
Hello All,
I got my 57HDX82 up and running. The only concern I had after packing was some very minor scratches on the outer edge of the screen on the lower right side and a few of the same thing on the left side. These are very minor buff marks. I was able to clean most of them off or hide them with Plexus. You can only see them when you are about 5 inches away. You can't even see them when you watch it. I don't think it was from shipping. More likely they rubbed against the plastic case during install. I would not be surprised if this kind of thing is common actually.
Minutes after turning the set on I turned down the contrast. It is set at 34 right now but I think I can go down a little more. It is still pretty bright in bright shots.
After 45 minutes I set the color and sharpness controls. I turned off all the special enhancement modes for picture quality. After that I did the 9 point convergence. It looks a lot better now then out of the box. Tomorrow I will do Avia.
This is my first 16x9 set. I am a little lost on the zoom options and every manufacture does it a little differently. If want the best picture quality and don't want to loose anything it looks like Theater Wide 1 is the best option. Depending on the aspect ratio you will get very thin black bands or slightly larger ones for 2.35:1 movies. Theater Wide 2 zooms in more. Theater Wide 3 does something completely different as does Full picture size. I will learn more about these as time goes on.
During my first 100 hours I will be making sure I am zoomed in as much as necessary to prevent any sort of burn in. After that I will mostly use Theater Wide 1.
As for picture quality I am really happy with it. I am sure I will be even more happy after running Avia.
Some of the minor issues I see could be because I am using an old DVD player. It does not support progressive scan or even have component outputs. It does not even have a 16x9 mode. After I am done typing this I am going to try my Sampo DVE-611. It does not have progressive scan but it does have 16x9 and component outputs. I will see how this looks but to be honest I should really upgrade.
I do have the buzz at low volume levels in my left speaker. After I register I am going to call Toshiba and have it fixed. Fortunately it goes away when you turn the sound all the way down. This is good because I will mostly be using my 5.1 set up.
Overall I am very happy with this set.
Chris
Chris
