Jon Hancock
- Mar 18, 1999
Ron,
This looks a *lot* better than your original graphs- one question for you- are you (or the program) taking into account the difference in time offset, assuming you're mouting the tweeter and midwoofers on the same baffle? It *looks* like possibly you are, since the woofer corner and roll off is softer and slower, which would introduce some phase shift to compensate for the time offset- and you're summing pretty nicely. Impedance curve looks fairly realistic, assuming a box tuning of about 32-33 Hz, and that that is a bit above the actual driver free air resonance (lower hump is taller...).
You can also do a check by reversing the phase on the tweeter, (in simulation) and seeing how deep a null you get. If you get a 24 dB or better null at the crossover frequency, you're about as close as you're likely to get with simulation without your own measured curves.
The only real question I'd have to raise is that I think you've implemented the best curve possible for these drivers, using this approach- but note that the 2 K peak on the midwoofer is only down about 8 dB. That may still produce some audible affects. I've found it's helpful (when you get to the hardware stage) to listen to the filtered driver output; if you hear any "crud" in the rolled off response, (with the tweeter disconnected), you're going to still wind up with some grunge and edge in the presense region, though with the tweeter playing you'll be harder put to identify the source (masking).
Take a look at this measured test box curve with a HiVi M8a- the 2.8 kHz peak of the driver is down 40 dB. When you listen to the driver and crossover by itself, it's rolled off, but it's also "clean"- no crud in the output from the driver cone modes.
Good work- you've definitely made some progress with the tools.
Best regards,
Jon
Best regards,
Jon
