Ron D Core
- Mar 31, 2002
I designed this 4th order Linkwitz-Riley x-over for my MTM tower setup. How do these graphs look? The amplitude graph is mostly within a 3dB range, but the corner frequencies are half an octave apart. The Focal 7k4211's have a 6dB spike in the upper range and the corner frequency separation plus the impedance EQ's are all I could think of to take care of it without a notch filter. Is it a bad thing to separate the frequencies like that? Other than that I have a big problem with the system impedance. In the upper range its over 4 Ohms which is fine, but it dips to 2.4 Ohms around 50 and 500 Hz. Would it hurt anything to add a non-inductive 3 Ohm resistor between the amp and the x-over? Wiring the woofers in series messes up the amplitude response significantly and doesn't seem to help the impedance much anyway. The phases between the woofers and tweeter (Focal TC120TD5) are no more than 50 degrees apart where they are summing and right where they cross, they are about 35 degrees apart (when the polarity of the tweeter is reversed). Does this seem ok? One last thing, i've been looking at the Solen capacitors from PE for all the caps accept for the 80uF. Should I spend the money on them or would it be ok to use cheap caps and bypass them all with some .1uF's? Heres the setup as copied form x-over pro...
2-Way Crossover Network
Low-Pass (LP) Filter: 1 required
Type: 4th-Order Linkwitz-Riley
Desired Corner Frequency: 2000 Hz
High-Pass (HP) Filter: 1 required
Desired Corner Frequency: 3000 Hz
C1 = 5.1 µF, Solen MP
C2 = 8.2 µF, Solen MP
C3 = 39 µF, Solen MP
C4 = 9.1 µF, Solen MP
L1 = 0.2 mH, Air Core(16gauge), DCR 0.18 ohms
L2 = 0.9 mH, Air Core(16 gauge), DCR 0.44 ohms
L3 = 0.47 mH, CFAC(16 gauge), DCR 0.22 ohms
L4 = 0.22 mH, CFAC(16 gauge), DCR 0.13 ohms
Tweeter
Impedance EQ
Req = 8 ohms
Ce = 3 µF
Woofer
Impedance EQ
Req = 2 ohms
Ce = 80 µF
Tweeter
Impedance EQ
Req = 8 ohms
Ce = 3 µF
Woofer
Impedance EQ
Req = 2 ohms
Ce = 80 µF
