Mark Russ
- Jun 23, 2002
If everything else was equal, ie. price and warranty coverage, what wouild you choose between a new NAD C372 integrated amp or a new in box, but previous generation C160/C270 pre amp and power amp combo?
I am aware that the C372 integrated does have slightly more power (30 watts per channel) than the C270 power amp. Also, the 372 would require a seperate phono stage whereas the C160 preamp wouldn't. But that is not neccesarily a bad thing as seperating the phono stage from the power amp section would negate one advantage the the seperates would have over the intergrated wouldn't it?
Is an intagrated about as good as true seperates since the nasty tuner section is seprate from the power amp section? Just like Adcoms tuner/preamps that mate with their power amps?
Opinions please, and thanks in advance.
