I just bought a new house an plan on developing the basement right away. I attached a rough sketch of my basement that has no dimensions on it (if you must know the nook at the bottom is ~12 feet).
In my basement I want a home theater room, small bedroom and bathroom, and a storage room. The basement has 9.5 ceilings, similar to a bi-level home. I notice golden room dimensions require low ceilings, narrow width, and long in length.......which does not fit very well. Is there a way I can take advantage of my high ceilings and maybe have the room somewhat open so that the basement is not so enclosed?
Anyway here is what I had in mind so far. Correct me if anything looks wrong:
- Wooden floor placed on the basement concrete floor. Made from 2X4's and plywood to get some floor shaking bass
- Drywall on ceilings and walls (maybe even doubled-up)
- 6" walls so that I can stagger 2X4's in the walls and weave insulation
- Carpet
- Projector and screen
- Acoustic foam on walls between viewer and front speakers
- No idea for seating
- small bar at back of room
- Not sure where to place two 15" powered subs
- Wall lighting to look like a theater
- Outdoor door so that it is more sound proof and doesn't rattle so much
Suggestions?
- Carpet
Suggestions?
