KeithO
- Oct 31, 2000
I'm trying to build a new HTPC and would like to use an ATI all-in-wonder. I won't be using the system for anything other than TiVo basically (no gaming, no dvd viewing, etc.).
Are there any differences in the 7500 / 8500 / 9500 / etc series that would lead me to buy one of the newer more expensive ones over one of the older radeon ones? I'm aiming for SVCD-quality recordings from the tv (can the ATI do that directly, or does it have to record avi and then convert to mpg?), just to watch, not to burn to a true SVCD. I like the improved visual quality and stereo sound of the svcd level compared to vcd level (I don't remember the differences in the mpg codec names used between the two). I'd rather do as little format conversion as possible, since I'm planning on only using a P3-700, which takes forever to encode. I've checked the ati site, but can't really tell if the differences in tv & video features between the cards are hardware, or if its just hyping different software features that are available on all the radeon-based wonder cards. I'll probably load the system with Win2k, a 120GB hard drive, etc. Any suggestions on RAM (128 or 256?) would be appreciated. Also if anyone knows of a good wireless keyboard/mouse with a 20+ foot range I'm all ears. I appreciate any advice you can give.
KO
KO
