Garret_O
- Sep 11, 2002
Hello all-
I'm new here so take it easy on me!
I've read the sticky at the top of the forum and I think I might be ok with this question.
I'm looking for a new 12" driver for my HT setup.
Right now I'm using two identical "cubes" each consists of:
JL 12W1 http://www.jlaudio.com/subwoofers/pdfs/12W1_BDS.pdf
Painted Black Cube: 15 3/4" X 16 1/2" X 16 1/2"
With an internal volume ~2.4 FT3
Port 3 1/2" Dia, 5 1/2" Long
Filter @ 120Hz (I also use my Reciever's crossover on the LFE)
Well, I made these boxes several years ago (at least 7) and I'm looking to upgrade, or switch drivers. I like the JL drivers but I'm itching for something new.
Given these dimensions do you have any suggestions? I don't need a driver that is capable of 600Watt RMS loads but I would like a driver with solid Bass extension and one with minimal rolloff in the 20-30Hz range (wishful thinking in a 12" I know). I can recut the Port if need be to retune I could also close the port if need be.
My current amp is only 100Watt RMSx2 @ 8Ohms. It is driving the 12W1 @ 4Ohms no problem (12w1 are rated @ 125Watt RMS anyway).
I've heard the Shiva 12" are good drivers and Almost anything from Stryke Audio. Are there any good HT drivers that are fancy looking? (I have no grills )
Thanks in advance,
Garret
Thanks in advance,
Garret
