Derrik Draven
- Dec 7, 1998
- Chris
Strange thing. My 16-46pc, which is about 10 months old, always performed flawlessly. Now that I had to move my HT system upstairs, after 2 months of being shut off, my SVS now hums; rather audibly.
It still makes the typical SVS killer bass but, when everything is quiet, it drives me crazy with it hummmmmmmm.
When I turn the TV off, the hum goes away. I haven't tried it yet by unhooking the cable. I'll try that tonight.
You'd think that the tv/cable would be the culprit but, when I'm watching a DVD, and I'm on an animated menu, when the sound loop ends and it restarts, you get that moment of silence. Well, the SVS goes silent too....with the tv still on.
Also, I have 2 Def Tech BP2000TL's that are on the same line, and are powered (much more so than the SVS's internal amp), and they are absolutely silent.
Why would the SVS be the only one affected? And, if the cable it causing the hum, how come the hum disappears when there is a soundtrack break on a dvd menu? Shouldn't it always hum when the tv is on, regardless of what's happening with the dvd???
Kind of confused here. Can't figure it out.
Thank you for any help you guys can give.
