bobbyg2
- Feb 23, 2007
- Bobby Geiser
Would removing the wood at the end of the port make up for the amp/driver/bracing displacement? How should I go about bracing this, just with a few cross members of MDF going through the middle?
EDIT:
Anyways, I tried modeling other similarly priced drivers, just to see if the Dayton was my best bet. I used the same amount of power (300W) unless otherwise stated, along with the same 5ft^3 enclosure. Here's my findings:
Elemental Designs 13Kv.2
(still had 2mm left until excursion was met, used a 20Hz Highpass)
Mach 5 MJ-18
(this was modeled using 500W with a 20Hz Highpass and a 25Hz tune)
And, that's pretty much all I can find in the $100-$150 price range... I still think the DAyton is my best bet, do you agree?
EDIT:
Mach 5 MJ-18
