DuWayne
- Sep 8, 2003
My Sanyo Z2 Impressions
Lets start with the Specs:
Resolution
WXGA-H (1280 x 720)
Brightness
800 ANSI lumens
Contrast Ratio
1300:1
Uniformity
85%
No. of Colors
16.7 million colors
Aspect Ratio(s)
16:9
Display Type
LCD; 0.7” TFT Poly w/Micro Lens x 3 (16:9)
Compatibility
Data Signals
Native Resolution (1280 x 720 pixels) Also Supports SXGA, XGA, SVGA, VGA
Video Signals
The PLV-Z2’s wide 16:9 aspect ratio along with it’s (1280x720) resolution HD-proportional panels, Progressive Scan and 3-2 Pulldown system for DVD playback make it the perfect match for viewing 16:9 widescreen DVD movies (480i, 480p) and HDTV (720p, 1035i
Video Resolution
H Sync
15-80kHz
V Sync
50-100Hz
Dot Clock
100 MHz
Inputs
Component RCA (Y,Pb,Pr) x 1
Composite Video (Single RCA) x 1
DVI with HDCP (DVI (Digital Visual Interface) with HDCP (High Bandwidth Digital Content Protection)) x 1
S-Video (Mini DIN 4-pin (Y/C)) x 1
RS-232 (Serial) x 1
Lens
Manual Zoom and Focus (1:1.3 zoom ratio) Short Zoom; F2.0-2.54 / f0.85-1.09
Image Size
31 - 200 inches diagonal
Throw Distance
3.9'-20.0'
Keystone Corr.
Digital Keystone Correction +/- 20°
Lens Shift
Manual; (Up/Down/Left/Right)
Proj. Methods
Front/rear, Desktop/ceiling
Items Included
Backlit I/R Wireless Remote Control, AC Power Supply Cord, Owner’s Manual, Composite Video Cable, 2 “AA” Batterieis
Remote Control
Backlit I/R Wireless Remote Control included
Projector Warranty
Three years parts and labor; 90 days lamp (original); 30 days lamp (replacement); Quick Repair Program under warranty
As there is a Great review for the Sanyo Z2 at Projectorcentral.com there is no need to to get too down and dirty with my review. There is one point in the review at ProjectCentral that I will disagree with. I would not suggest a “gray” screen with ANY low lumens projector. I suspect a 30% loss in brightness. Now to m thoughts:
Calibrations:
I was shocked after inserting my DVE 2003 for HDTV in my Samsung HD931 and notice that out of the box, the Z2 was almost perfectly calibrated. At least through the DVI input. I only changed the Sharpness, Brightness and Contrast.
My Settings: (DVI)
1/2 lamp power /w Aperture wide open
Sharpness:-7
Contrast: +4
Brightness:-3
Red:0
Green:0
Blue:0
Gamma:0
A great feature is the ability to store these settings in 1 of 4 memory queues. There are way more settings, but I list the more important ones.
My Screen size:
111 1/2" Diag.
Picture Quality:
I am absolutely satisfied with my picture; more so than my old LCOS (“old” LCOS is an oxymoron right?). Mind you , that I am satisfied while only projecting on to a Textured Wall. Blacks are fine, color is fine and brightness is fine with somewhat controlled lighting. I watched it at high noon and still can get a very descent picture to view. The only issue that I have came across while watching the Z2 with a lot of ambient daylight was with dark scenes. Other than that, all was fine.
Sound:
Not Applicable
Non-HD content:
Just as good as any other native 720p set converting an 480i OTA/SAT source. I did have to set the Sharpness setting to “0”; “-7” was a little too soft for the mentioned source. I am using the Component inputs for the DirecTv 480i source.
I will field any questions if you have them…
Resolution
WXGA-H (1280 x 720)
Brightness
800 ANSI lumens
Contrast Ratio
1300:1
Uniformity
85%
No. of Colors
16.7 million colors
Aspect Ratio(s)
16:9
Display Type
Compatibility
Data Signals
Video Signals
Video Resolution
H Sync
15-80kHz
V Sync
50-100Hz
Dot Clock
100 MHz
Inputs
RS-232 (Serial) x 1
Lens
Image Size
Throw Distance
3.9'-20.0'
Keystone Corr.
Lens Shift
Proj. Methods
Items Included
Remote Control
Projector Warranty
Calibrations:
My Settings: (DVI)
Sharpness:-7
Contrast: +4
Brightness:-3
Red:0
Green:0
Blue:0
Gamma:0
My Screen size:
111 1/2" Diag.
Picture Quality:
Sound:
Not Applicable
Non-HD content:
