Chris Ryan
- Apr 14, 1999
Hi:
I have an Onkyo TX-DS 939 powering 6 Def Tech. inwalls with 3 Niles Audio Intellipads. The Onkyo has a 6-ohm load minimum. My problem is, one set of speakers is connected to the center channel & one set is connected to the L & R surrounds. Well, the sound isn't the same from the center and surrounds. The only way you can fix it is to hook up three speakers each to the left & right channels, therefore bridging the Onkyo down to 2 ohms on two channels. That won't work. The only other thing I could think of is to buy an infrared speaker selector or an amp. An amp is too expensive.
Any other ideas?
Chris
Any other ideas?
Chris
