Jason Green
Grip
- Feb 22, 2004
Anybody else have a 5.1 surround sound music setup that also has 7.1 movie setup. How do you place your speakers? I have 2 x Sinclair Audio SA285's in the front on either side of my entertainment centre. The left one is about 2 ft from the side wall & 1 ft from the back wall, toed in slightly (approx. 20°) My right speaker is just to the side of where a doorway leads into the rest of the basement, with about 4.5' from the sidewall. My centre (Athena AS-C1 is on top of my 46" Sony widescreen. I have 2 Athena AS-B1's on my sidewalls upside down with the tweeters down instead of up. (just over 6' to the tweeter). Then I have another set of Sinclair Audios SA285's currently in the back corners pointed towards my sweetspot. This semms to be really good with the multi-channel, but not so good in the 7.1 setup with them as rear backs. This is where I need the help. With my Yamaha RX-V2400 I can switch which speakers are my surrounds in digital & in Multichannel. So when I am watching a movie the back Sinclairs are my back surrounds, but when I am listening to DVD-a's then my side surrounds are off and my Sinclairs are my side surrounds. Confusing? Last night I switched my backs in the corners to be about 4' apart pointing straight into the room. I thought I noticed a definite improvement in the sound but possibly more localizable as well. Any hints suggestions or somebody else with the same dilemma would be appreciated. My wife thinks i'm crazy to be moving speakers around depending on whether I am listening to music or watching movies & it is a pain as the speakers are about 55 lbs.
Thanks.
Thanks.
