MarkHastings
- Jan 27, 2003
I've been to all the home improvement stores and can't seem to find anything that will fit my situation the way I'd like it to. I want a motion light in my garage because there are no windows and it is PITCH black in there. I need the light to work when I enter the garage from the house and enter the garage from the laundry room (on the opposite end).
Here are the major problems I am running into:
1) I tried to install one of those motion detector light switches, but the garage light is on a 3-way switch and these motion switches HAVE to be installed on the main switch (which is in the laundry room), so that doesn't work.
2) I looked at one of those motion lights that can replace the current ceiling mounted light; something like this - they actually has ceiling mounted lights (with 360 degree range) at Home Depot, but I couldn't find it online...I even saw one of those light bulb socket things that screw into the socket, then you screw the light bulb into that. This would work when entering from the house, but when you enter from the laundry room, there is an area about 8x5 feet that drops down a good 2 feet (I believe this is where all of the central air ducts are), so you'd have to walk a good 3 feet into the garage before hitting the sensor beam.
3) I looked into one of those wireless sensors that transmits to either a light socket or a plug in switch, but the sensor requires batteries. While this may be my only solution...I would prefer to avoid having something that requires batteries.
I have an A/C outlet in the back corner (near my workbench) and I could easily clip a light to the workbench. This would be perfect and in a great spot, but I don't think they make something like this - I want some kind of extension cord or power strip that has a motion sensor on it.
The guys at Home Depot didn't think anything like that existed...Anyone know of something like this or something similar???
