Lawrence F
- Feb 8, 2000
All trade offers considered or will sell for $1200. Retails for $6000 US.SUPERLATIVE picture.Unit has seen very little use.
This 37" monitor is ideally suited for a variety of institutional,
commercial and corporate applications. From executive boardrooms to
factory floors, the Monitor provides an exceptionally large color
display that is bright and bold, even in high
ambient lighting.
The specifications are as follows:
CRT Stripe Pitch 0.85 mm center/1.05 mm corner.
Maximum Addressable Resolution RGB: 800 X 600/75 Hz NI
Auto-Scan Range H: 15 to 61 kHz; V: 40 to 120 Hz
Scan Mode Memory Microprocessor-based
Remote Control Wireless multi-function remote control with on screen
display
Inputs Signals & Connectors:
Analog RGB 5-BNC RGB input/output, D-sub 15 pin input connector
TTL Connetor 9 Pin Connector
External Source Select 9 Pin Connector
Video 2-BNC input/output, 2-RCA input/output, 1 S-VHS input
Audio 5 RCA L/R input, 1 L/R output variable, 1 RCA L/R fixed (line)
Other:
Audio Stereo audio;2 internal side firing speakers
Power Requirements 100-120 VAC or 220-240 VAC/50/60 Hz (switchable).
Power Consumption (Average) 380 W (approximately).
Physical Dimensions (WxHxD) 34 x 29.25 x 22.65" (865x742x576 mm)
Weight 217 lbs.(98 kg)
Virtually the same model can be seen here:
http://www.mitsubishi-display.com/products/mv37.html
ambient lighting.
display
Other:
