Eric T
- Apr 1, 2001
I recently bought a Denon 3802 receiver, which has component video switching. However, I can't figure out a good way to get it to work with my TV. The reason is because I have the following sources:
- DVD progressive component
- Cable box S-video (to cable input of TV, to view stretched)
- Cable box component (for Hi-Def channels to 1080i input)
- VCR (composite)
It seems that the 1080i input will not accept any other signal...am I mistaken on this? If that is the case, then I can't use a single output from the receiver to view all of my sources, can I?
Can anyone help me figure out a way to make this work? I hate having to switch the TV input manually all the time, and since the Mits remote can't directly access the different inputs (you have to go through them sequentially), I can't program macros on my Sony touchscreen remote.
- VCR (composite)
