Bjoern
- Jul 16, 2000
I have just replaced my old DVD player with a DV-757Ai (I think it's called Elite 47Ai other places in the world).
I have connected the player with both a coax and 5.1 analogue cables to my receiver, so that I would be able to use the players DTS decoder (my receiver has no DTS capability).
While I have no problem with the digital output and DD, I can't seem to get a LFE signal out of the beasts analogue outputs.
Just to be certain that something comes out, I have used the players test signal, and connected the subwoofer signal to my center speaker, and in that case I get a test signal on my center speaker. To me that means that a signal is going out, but that I can't get it through to my subwoofer. Also - the signal seemed to be the same as was played on all the other speakers, which is to say somewhat bright. When testing with the receivers internal test signal, a deep rumble comes out of the woofer.
Is there something I need to do to make this work, or am I out of luck with regard to getting usable LFE signal out of the players analogue outputs?
