Stephen Dodds
- Aug 29, 1998
Howdy.
I have Wilson WATT speakers. A while ago I replaced the Puppies with Entec subs, to good effect. But when I moved back to Australia recently, the Entecs were just too much to ship. I figured I could simply use the WATTs with a good sub, but I'm now feeling the system lacks a bit of midbass power.
So I thought this might be a task which suits a first wander into DIY. The plan is to construct a midbass system to cover the range from 200Hz down to about 80 Hz. The enclosures would be 24h x 16d x 11w, presumably sealed.
I would be using an active crossover, and I use active full range digital EQ via a TACT.
The current sub is an EBS aligned Shiva, and I also have a pair of NHT SW2 passive subs I use with my rears.
The new units would also act as stands for the WATTs, hence the dimensions.
Any thoughts about drivers which might suit such a project, other considerations or advice would be gratefully received.
To complicate things, I am in Australia, which makes the choices both more limited and more expensive than from the US, although I travel a lot so I can pick up things there.
Cheers
Steve
Cheers
Steve
