Rich Malloy
- Apr 9, 2000
If bypass is so important for your two channel needs then why not just run out and buy a creek obh-12 passive volume control and go straight form your source into the creek and directly to your amps...Total cost about 200.00 and it doesnt get much cleaner then that.
I suppose the only reason I don't run out and do just that is because I don't know whether it will also decode DTS/DD for home theater applications. If not, then do you think it'd be smarter for me to get the Creek and a separate pre/pro for home theater... or just get something like the OUTLAW that does both?
(I mean, is that a serious suggestion or a dismissal?)
