Isaac C
- Aug 1, 2000
Hi,
It is settled -- my first Shiva sub will be of box type At AU$161 for a 24" by 4m tube and AU$60 to have it delivered, Sonotube is just too costly for me at the moment (when I only need a 24" by 21" tube)
Depending on the size of ready-made ports, I'm looking at a box that is 21" deep, 15" wide and 35.5" high... max.
Available in our local hardware store is 16mm MDF panels. Considering for the time being the above-mentioned box dimensions, would a box which uses two 16mm panels per enclosure wall (for a total of 32mm), using only a frame of corner braces, sound more "dead" compared to one which only uses 16mm panels and 5 panel braces?
Thanks in advance!
Isaac
Subwoofer Simulator: http://www.geocities.com/f4ier/subsim.htm
Factor Conversion Tool: http://www.geocities.com/f4ier/fct.htm
[Edited last by Isaac C on September 26, 2001 at 12:28 PM]
Thanks in advance!
Isaac
