Ryan Hawke
- Jul 10, 2001
I'm working on a design for a sub for my house that I'm moving into and would like to build a coffee table sub with a Tempest. I think the Tempest would be enough output and my only worry is building a table that is sturdy and won't shake during loud/low bass hits. I drew up a preliminary design and used double thick MDF all around. Using 48 lb/ft^3 as the density of MDF (stated in MDF FAQ) I found my box, wood alone, would weigh about 160 pounds. I would actually like to tweak this around so I have enough volume to do the Adire algnment (currenly my design is at 170L, but I'm sure I can add more by tweaking some things), so this might be a little higher. Would this be bulky enough to be pretty dead during loud LFE in movies? Should I go with a single layer and a lot of bracing instead? I'm open to any suggestions. Also, I'd like to make a plug for the port so that when listening to music I can have that nice low Q sealed sound that I love. What have people used for port plugs here? Thanks to all for reading this and TIA for suggestions!
--Ryan
--Ryan
