Omiros_n
- Jul 10, 2003
Hello there,
i'll go straight to the point because my post is too large anyway.
I have the following system:
Yamaha DSPA-595a (5x70W)
Roister Silk 120 (120W, 8 Ohm) (Front)
Panasonic (70W, 6 Ohm (Rear)
and everything works and sounds fine for 3 years now in both stereo and AC3 programs (Phantom Mode)
Background (not very necessary to read that):
Recently i decided to add a center speaker to the system (although the Roisters produce excellent dialogue) to improve the localization of the center channel. Since, the amplifier has the ability to send the low frequences of the center channel to the front speakers, i decided to buy a smaller center (the Roister Centers are too expensive). So i bought an
Eltax C3 Liberty Center (70W, 6Ohm)
The problem:
When i connected the center speaker i realised that there was a SEVERE distortion to the dialogue. I tried decreasing the volume, switching cables and speakers but the problem remains. It seems that the problem is to the amplifier. Do you agree? It probably existed for ever, but i didn't know it because i never used the center channel. Unfortunately, the amplifier is out of warranty now, do you think it would be costy to fix it?
One idea by me:
2 years ago, for some reason someone in my family turned the volume to maximum while it was off. I didn't notice, so i turned on the CD-player, then the amplifier...and that was the death of the midrange of the right front speaker (that was fixed).
I think maybe that also may fried the center channel amplifier, since there was no speaker connected (less Ohms, more current), but since i had it to No Center Mode the center amplifier should be totally inactive (ehmm..right?). I am not really into the technical stuff so i am probably totally wrong.
Thank you very much in advance.
Omiros
The problem:
One idea by me:
Omiros
