- Apr 23, 2000
- Alfer
Hello,
Sorry for the length, but want to cover everything I've got...
I needed to replace a ceiling fan in one of bedrooms that stopped working.
Stupid me, I didn't write down how IT was wired up, now putting the new one up has become a problem.
The house was built in 1983 and the current wiring that is in the ceiling outlet(this room only) is THREE BROWN WIRES, and THREE WHITE WIRES, and the ground (very thick gauge).
What's strange is when I disconnected all the wires from the old fan it caused the neighboring rooms overhead light and closet light to not work, and the closet light in the bedroom I'm working in doesn't work (although the wall outlets work) Leads me to believe that the overhead outlet with the 3 brown and 3 white wires are tying the two rooms together somehow.
The steps I did to connect the fan w/ light were as follows.
-- Used a wire nut to connect the THREE BROWN wires and blue and black wires from fan...
-- Connected the 3 white wires to the ONE white wire from the fan.
-- Then connected the green ground wire from fan to ground screw in outlet box.
I then went to the garage and flipped the circuit switch and heard a slight hum, and nothing happend...no power to anything that was on that particular circuit. I quickly shut it off an diconnected all the wires for now in hopes someone can assist me in figuring out what to do.
After I disconnected the wires, I flipped the circuit breaker switch and all my power is restored to the appropriated lights etc. (however the overhead light and closet lights are not working until I wire the fan)
I did tear apart the fan in the neighboring room and it had TWO white wires connected to the one white fan wire, and ONE BROWN wire connected to the fan BLUE and BLACK WIRE.
I hope there are some electrical wizards out there that can help me out!
Thanks in advance
Alfer
Thanks in advance
Alfer
