SteveK
- Jan 10, 2000
I was wondering if paper labels can be safely applied to DVD-R or DVD-RW. I'm referring to the round labels that would cover the entire disk, not a rectangular label that would only cover a portion of it and might affect balancing of the disk. I've read that it is not a good idea to apply labels, but I've also read that you shouldn't use markers directly on the DVD, and obviously you have to "label" it somehow.
I've used labels on CD-Rs with no apparent problems, but I wanted to check if they can also be used on DVD-R.
Thanks in advance for any comments.
Steve K.
Steve K.
