JohnMcCallum
Grip
- Nov 8, 2003
These center speakers can be found for around the same price and I was wondering on which speaker is better.
JBL SCenter II Specs:
General Section
• Maximum Recommended Amplifier Power: 150 Watts
• Impedance: 8 Ohms
• Sensitivity (2.83V @ 1m): 91dB
• Frequency Response (–3dB): 75Hz - 20kHz
• Crossover Frequency(ies): 800Hz, 3200Hz
• High-Frequency Driver: 1" Pure-titanium dome with EOS™ waveguide
• Midrange Driver: 4" PolyPlas™
• Low-Frequency Driver: Dual 5-1/4" PolyPlas™
• Dimensions
(H x W x D): 7-7/8" x 20-1/2" x 9" (200mm x 521mm x 229mm)
• Weight: 15 lb (6.8kg.)
• MSRP U.S.: $299.99 each
Polk CSi30 Specs:
video-shielded
bass-reflex
frequency response 55-26,000 Hz (-3dB)
8-ohm impedance
sensitivity 90 dB
handles up to 180 watts
5-way binding post terminals
black wood veneer
19-7/8"W x 6-5/8"H x 7-1/2"D
General Section
• Impedance: 8 Ohms
• Dimensions
Polk CSi30 Specs:
video-shielded
bass-reflex
8-ohm impedance
sensitivity 90 dB
black wood veneer
