Richard_s
- Nov 25, 2000
JBL psw-d110 front firing 150w 10inch with rear port the PB10 replaced this in the JBL line. This is my sons subwoofer.
The JBL subwoofer run on the same exact system as my new Sony SA-wm10 seems to have much more explosive effects . They both have pretty much the same low frequency limit (tested with AVIA) located in the same place in my room and both are front firing rear port models. Both were set up the same way using AVIA.
How is it possible that the JBL psw-d110 10" 150 W can shake the room (heavy floor vibration) and the sa-wm40 does not even vibrate the floor. The sa-wm40 seems damped or muted in comparison to the JBL. The only difference in the set-up is that the JBL hook-up uses the L&R preamp outputs of my receiver to drive the JBL and the Sony is hooked Up using the speaker connections. Can this make a difference?
I just can not figure out why there is such a difference unless maybe the Sony starts to "clip" on these explosive scenes and the JBL does not.
I was very happy with the Sony until I ran the JBL against the Sony. I was happy without the physical effects (vibration) but the magnitude of the sound is not there either.
This does not seem to make sence or does it. I am thinking of returning the sa-wm40 and getting the PB10 but the PB10 is a down firing unit and may not work well on my carpeted floor so it may not work as well as the psw-d110.
What would you do? Sorry just getting a little frustrated most feel that the PB10 and the sa-wm40 are equivalent from what I read is it possible that the older psw-d110 is just better than either the sa-wm40 and the PB10
