William C
- Oct 13, 2000
I'd hate to have to run cat5 thru the house. Would 11MPS be ok for xbox live?
you can buy a wireless bridge from linksys that turns any wired device into wireless...Could you explain this further? Thanks...
Is there a way to get that ethernet on the Xbox to use the wireless capability on my existing router?You'll have to do what mike suggests - go buy a bridge which will connect to your current wifi router. YOur xbox will plug into that, which will be transparent to your xbox, and then will connect to your current wireless router. Think of it as a 'wireless card' for your xbox - except that it's completely external and that you hook it up via your ethernet port on your xbox.
i heard that the wireless devices are very "picky" when near other electronic devices.Not unless your other electronic devices put out signals in the 2.4 ghz range. I know phones and microwave ovens do, but I also know a bunch of folks that have those phones and microwaves and run wireless just fine.
