Inverting display on laptop? (1 Viewer)
TimDoss
If I were to mount a laptop upside down, is there a way to invert the picture?
KyleS
Now why would you want to go and do that? ;)
To my knowledge no there is not a setting that would allow that. You could open the case and flip the display upside down but I am not sure that case would like that. (little pieces that wouldnt fit.
KyleS
Leila Dougan
It depends on what operating system you run, chipset, etc. I know video driver utilities, such as those provided with ATI and Matrox cards allow for inversion. It may also be possible with a 3rd party app (assuming you're running some Windows variant).
TimDoss
I'm running Windows XP, an ATI (can't remember exactly which, M1 I think)... I want to invert the DVD playback...
I haven't seen anything in the driver utilities for it,
do you know what I should be looking for?
Thanks for the responses.
ChewyWaffles
