Vlad_O
- Oct 16, 2003
I hired some person, who installed the speaker cable in my house (inside wall).Basically he installed 18 Gauge cable.
I have 5.1 Infiniti speakers and just ordered Harman/Kardon AVR 235 recev.
Here is info from manual AVR 235 regarding cable:
Regardless of the brand of cable selected, we recommend that you use cable constructed of multistrand copper with a gauge of 14 or smaller
So, unfortunately I can't change cables.
What am I going to loose? Can I loose something on high frequency? Or this is most issue for the bass?
Can I loose something If I'm going to listen not with high volume?
Thanks, Vlad
Thanks, Vlad
