If I order a Pioneer 45TX now, will I get a unit that has had the "fix" applied? (1 Viewer)
Brad Newton
I don't to make this purchase and have the shut down problem. Is there a mfg date that guarantees that this problem has been corrected?
Pete GTP
I believe its Oct 02 or later and its fixed. I just bought a 45TX with a mfg. date of Feb 03. It has the update. Check with the dealer your buying it from for the mfg date. You will definately be safe with an 03 model which should be the case if your ordering it now.
zeus_r
i have a pioneer 43TX mfd august 2002 , and i seem to be experiencing this shutdown problem very frequently, granted im getting new front speakers to replace the current ones, but even at -6db it was shutting down.
Does anyone have any recommendations for a receiver in the $1400-1500 CDN currency price range?
neonpizza
