Bill Otten
Grip
- Jul 31, 2002
Hi.
I recently purchased this unit used. It was modified and now has a hard drive that will record 120 in the low quality setting. Here's my question/situation:
The unit works perfectly, but from time to time you can hear the hard drive start to spin (or at least that's what it sounds like) It is similar to the sound you hear when you turn the unit on. It makes this noise for less then a minute, and then stops. It is quite for a while and then does it again. Haven't figured out how many time is does it but it's at least 6 times a day if not more. It doesn't effect playback or recording in anyway, and dosen't do it when the machine is on.
Is this normal? Is it something I can stop from happening? Any info would be much appreciated. Please email me at [email protected] or post here for all to read.
