Chuck C
- Jan 6, 2001
If an amp has a 12V DC trigger, does that mean it turns on upon sensing a surge in the analog cable that connects it to the preamp or receiver?
thanks
thanks
2) cut out connector, and stripped wires;
3) used multimeter to find where is + and -
4) connected wire to Parasound (again, there is a special terminal for trigger);
What happens if you make a mistake on which wire is + and which is -?
I think your Parasound power amp has a 12V DC trigger input. But my amp doesn't have a 12V DC trigger input. I think I need a switchable power supply to turn power on. Presumably I'd plug my amp into the switchable power supply. I'm looking for a very inexpensive switchable (via 12V DC) power supply.
Hmmm, your power amp doesn't have a 12V trigger. What kind of amp is it?
You might want to look at X-10 stuff then. Got to www.x10.com
get a "AM466 Appliance Module - 3 Prong Grounded" the "Universal UltimateREMOTE (UR47A), Transceiver Module (TM751)"
You will be able to plug your amp into the appliance module and be able to turn it on and off with the X10 remote. The remote is RF not infra red so you will not be able to use a learning remote to control the x10 stuff unless you buy their RF to infra-red receiver/transmitter.
It will cost you about $20 for the remote and transmitter and $14 for the appliance module.
You can call their tech support and tell them what you want to do and they will tell you all the parts you need to buy in order to have a complete system.
Rajeek on this message forum uses the x-10 stuff to control his power amp for his SVS subs, you might ask him. You can also look at his hometheater page....
Link Removed
Ken
Ken CustodioMike ZQ said:Quote:
The Monster HTS2500 has remote activation, but I don't believe the less expensive HTS1000 or HTS2000 has the remote activation feature
Hmm ... sorry about that! I looked at the description for HTS1000 and HTS2000 on Monster Cable's web site and it said "Switched and un-switched outlets" ... as did the page describing the HTS2500 (which also has timed outlets). Since I have the HTS2500 with the switch (which I bought used for $125), I automatically assumed that the HTS1000 also has this (and I saw that it sells on ebay for under $100). My mistake!
Incidentally, Niles Audio has a unit (item AC-3) which also does this. It sells at onecall for $123 (including shipping).
